ZACZNE OD POCZATKU, JECHALEM I CHCILEM OTWORZYC NA CHWILE SZYBE LEWA (ELEKTRYCZNA), W NOCY BYL MROZ OK ALE ONA NIE DZIALA TJ SLYCHAC JAK SILOWNIKI CHCA JA OTWORZYC ALE NIC Z TEGO (CZY CUS TAM ZAMARZLO??? I TO PRZEJDZIE???) I TAK PROBOWALEM KILKA RAZY I NIC I POTEM DOPIERO BOL NASTAPIL. PODJECHALEM POD KRAWEZNIK TYLKO TYLNIA OSIA I ZJECHALEM Z NIEGO, I PO OK 5 SEK ZAPALILA MI SIE KONTROLKA PODUSZKI I NIE GASNIE !!!!!!! CZY KOTS WIE CO Z TYM ZROBIC BO DOWIEDZIALEM SIE ZE KONTROLA POD KOMPEM W ASO JEST ZA 120ZL A JA NIE MAM TYLE:(
CZY MOZE POMOC ODLACZENIE I PODLACZENI AKUMULATORA, CZY PRZYCZYNA TEGO MOZE BYC TEN PODJAZ I ZJAZD Z KRAWEZNIKA (CZY SA TAM, Z TYLU, JAKIES CZUJNIKI PODUCHY???)
LUDZIE RATUJCIE BO CHCE WYJECHAC A NIE WIEM CO Z TYM ZROBIC
POZDRAWIAM I Z GORY DZIEKUJE!!!:p
ehhh... temat poprawiony
