http://cgi.ebay.co.uk/Electric-power-st ... dZViewItem" onclick="window.open(this.href);return false;
a w razie gdyby link nie byl aktywny kiedys,opis:
Vauxhall Corsa B or C steering column controller
This is a super little device to activate and control the level of assist of the Corsa B or C columns.
Features the following :
-Simple to connect
-Easy to mount using Velcro supplied
-Light weight and Small but Tough casing
-Own Dedicated Printed Circuit Board (i.e. not Vero or strip board like the others!!)
-Easy to follow instructions.
-Available in two versions,
The two versions are the On Board adjustment version and the Remote adjustment version.
On Board Version is Ideal for the user who requires a calibrated assistance at the best price. The user can calibrate assistance using the slot screw on the side of the casing then offer up under the dash using the Velcro supplied.
Remote adjustment version is for the user that fell they may require the steering control at their immediate disposal. The Remote adjustment is mounted in a dedicated bracket for easy fitting.
***This listing is for the Remote Adjustment Version***
The units are offered with a 12 month guarantee
Please do not be misled by comments of individuals who sell similar pieces but with inferior build quality.
The comments are inaccurate and are just weak marketing
I offer a product with excellent operational history (check the feedback comments) having repeat custom;
The price is a reflection of a standardised batch production of the unit.
Thus offering you, the customer, a product of quality and reliability at a competitive price
ktos o tym slyszal i wie gdzie w PL mozna to kupic??
Regulator sily wspomagania EPS'a
- LETIS
Re: Regulator sily wspomagania EPS'a
chyba dziala to jak funkcja CITY w fiatach czy cos takiego. pewnie oszukuje to troszke sterownik ktory tak czy siak bieze informacje o predkosci pojazdu z ecu.... hmmm dziwna sprawa. ciekawe ...
C14SE
- -=kLaRi=-
Ja zakladamlem EPS-a kumplowi i nie podlaczylismy wogole kabla ,ktory pobiera predkosc z ECU ,nie ma abs itd wiec w sumie nie mialby jak tego sprawdzic i wszystko dziala
Kiedyś CORSCHE
Corsa B 1994 c20xe...
