"... There are 2 different body types.
All the Corsa GSI are always body type 2.
All the Corsa’s with power steering are also body type 2.
The different between the two body types are easy verify.
Body Type 1 is an outside engine mount.
Body Type 2 is an inside engine mount.
Gearbox mount front left, use original corsa.
Gearbox mount mid-rear, original corsa with a spacer of 12mm between de gearbox and the mount. Use longer bolts. ..."
Dziękuję Ci yosh, już któryś raz, Ty i ten temat, ratujecie mi tyłek
